AH-01A Visualizers
Why won't the AH-01A turn on after connecting the USB cable?
A. Make sure the USB cable is compatible. Use the cable provided with the device and avoid fast-charging adapters or cables, as they may damage the unit.
B. Check the sensitivity setting. If it's set too low, rotate the sensitivity knob clockwise to increase it.
C. Ensure the light bars are installed correctly. If unsure, disconnect the power, remove the light bars, and reinstall them securely.
Why aren't the lights syncing accurately with the rhythm of the music?
A. External noise may be causing interference. Try reducing background noise for better performance.
B. If the device is placed too far from the sound source, move it closer to improve sound pickup and synchronization.
1. Insert the two light bars into the top slots of the AH-01A base, ensuring the LEDs face forward, then attach the light tubes;
2. Power the AH-01A using the included USB cable (avoid using a fast charger to prevent damage to the device);
3. Adjust the light color, mode, and sensitivity appropriately using the control knobs on the front panel based on your listening environment.
