Banana Plugs
Closed Screw Type
All Fosi amplifiers use standard-sized speaker terminals, they are standard 4mm pins
Easy to wire up and solidly connect to amplifier and passive speaker
If they do not fit, use a little force to tighten the plugs
Fosi Audio Banana Plugs
✅ Material: Copper
Surface: 24K Silver Plated
Color: Red/Black Ring
☑ Plated Carbon Fiber Plug
✅ Material: Copper
Surface: 24K Gold Plated
Please watch the tutorial video by clicking on the link provided. https://youtu.be/6pYhoqDlvNw / https://youtu.be/RGvBgGAwS9k
How to Connect 4mm Banana Plugs to Speaker Wire?
✅ All Fosi amplifiers use standard-sized speaker terminals, they are standard 4mm pins
Please watch the tutorial video by clicking on the link provided. https://youtu.be/RGvBgGAwS9k
Closed Screw Type
✅ Material: Copper
✅ Material: Copper
