BOX X1
How to control headphone volume (BOX X1)
Since the BOX X1 does not have volume control, you'll need to adjust the volume on your input device. If your headphones have a volume control feature, you can use that. If not, you may want to consider getting headphones with a volume control button or a separate sound adjustment device.
How to adjust volume for 3.5mm output (BOX X1)
If connected to headphones or active speakers, you can adjust the volume on the headphones (if they have volume control) or on the active speakers.
Is the DC input jack center-negative or center-positive (BOX X1)?
It is a center-positive connector.
Can both headphone output and RCA output play sound simultaneously (BOX X1)?
Yes, they can.
Yes, they can.
Step 1:Connect the power adapter to the socket andthe BOX X1.
Step 2: Connect the MM turntable to the RCA inputsof BOX X1. Connect the ground wire to thegrounding post of BOX X1.Note: lf your turntable doesn't have a ground wireconnection, it's no need for a ground wirehooked up to work.
Step 3: ① RCA output: Use a RCA cable to connectthe active(powered) speakers or amplifierto the RCA output port of BOX X1.
②Headphone output: Use a 3.5MM audiocable to connect your headphone to the3.5MM headphone output port of BOX X1.Headphone impedance:≤32Q
Note:You can connect a power amplifier throughthe 3.5MM or RCA output, then connect thepassive speakers.RCA line output and AUX headphone outputcan be output simultaneously.
Step 4: Turn on the power switch. The power indicatorlight will turn red.The indicator light stays onwhen connected. Then you can enjoy HiFistereo music.
Note: Make sure that all the cables are completelypushed into the device.
