BOX X2
Can I use the BOX X2 with other audio sources like a laptop?
Yes, you can connect a laptop (via its headphone output) to the 3.5mm input on the BOX X2.
Why is the sound quality poor when connecting the Project Audio T1 Evo, BOX X2, and Marantz SR6014?
Please confirm if you have connected them as follows: Project Audio T1 Evo (PHONO Out) → (MM Input) BOX X2 (RCA Out) → (any (non-Phono) INPUT) Marantz SR6014 (Speaker Out) → Passive Speaker. Plug the RCA out from the BOX X2 into any (non-Phono) INPUT on your amplifier or receiver.
What’s the difference between BOX X2 and BOX X4?
BOX X2: Gain control, no headphone out. BOX X4: Bass/treble control, has headphone out.
What is an op-amp in BOX X2?
JRC2068D
Can I replace the tubes in the BOX X2?
Replaceable with 7-pin types like 6AK5, 6J1, 6J1P, 5654, EF95, etc.
How to connect a turntable to the BOX X2 and active speakers?
Ensure turntable uses MM cartridge and set to PHONO output.
My turntable has a built-in phono preamp. How do I connect it to the BOX X2?
If the turntable has a built-in phono preamp, switch it to "Line Out" mode and connect it to the 3.5mm input on the BOX X2.
If the turntable is set to "Phono" mode, connect it to the MM input on the BOX X2 for optimal sound.
What is the gain setting on the BOX X2, and how should I adjust it?
The BOX X2 has a 4-level gain control: OFF, 39dB, 42dB, and 45dB. Adjust the gain according to the input sensitivity of the connected amplifier or active speakers to optimize sound levels without distortion.
JRC2068D
How-to Video
How to Connect Turntable to BOX X2 & Active Speakers?
Step 1: Install the vacuum tubes to the BOX X2.
Note 1: Electronic tube is not divided into left and right,check the pins before installing the electronic tube there is no deformation, if there is a deformation of the situation you can use your hand to dial the right.
Note 2: Please note that electronic tubes are fragile and need to be handled gently.
Step 2(OUTPUT): Connect speakers to the BOX X2.
RCA output: Use RCA cable to connect the RCA line output of BOX X2 to your active (powered) speakers.Or use RCA cable to connect the RCA line output of BOX X2 to your amplifier, then use speaker’s wire to connect the amplifier with your passive speakers.
Step 3(INPUT): Connect the audio source (MM turntable input,3.5MM AUX input) to the BOX X2.
(1): MM turntable input: Use RCA Cable to connect your MM turntable to the RCA inputs of BOX X2,then connect the ground wire of your MM turntable to the grounding post of BOX X2.
Note 1: If your MM turntable is no need to connect a ground wire, the ground wire can be omitted.
Note2: MM Turntable Input can only be connected to the turntable, and cannot be used as a normal preamplifier connected to other audio sources,such as CD player, TV, etc.
(2): 3.5mm Input: Use a 3.5mm Audio cable to connect the BOX X2 and your device.
Note: Once 3.5mm AUX plug in ,the MM input will automaticallyinterrupted, so the input mode will turn to 3.5mm AUX input.
Input priority: 3.5MM AUX input > MM turntable input.
Step 4: Connect the power adapter to BOX X2 and the socket.Turn the Multi-function Knob ( Power Switch/Gain Adjustment Switch) clockwise for one time to power on the BOX X2.
Note1: The power adapter does not have a power indicator light,so connecting to the socket means power is on.
Note2: Before connecting the power supply, please make sure that the BOX X2 is in “OFF” position when connecting to the power adapter. Otherwise there is a “POP” click sound from your speakers.
When the connection is completed, please turn on the BOX X2 first, then turn on the amplifier (or powered speakers), at last turn on your turntable or other audio source, then enjoy.
Note: If you turn on the amplifier (or powered speakers) first, then turn on the BOX X2, there is a “POP”click sound from your speakers, it is normal that all the phono preamp have the same issues, please don’t worry about it, the “POP” click sound will not damage your amplifiers or speakers.
