Step 1: Install the vacuum tubes to the BOX X3.
Step 2: Install the Bluetooth antenna to the BOX X3.
Step 3: • Use RCA cable to connect the RCA line output of BOX X3 to your active(powered) speakers.
• Or use RCA cable to connect the RCA line output of BOX X3 to your amplifier, then use speaker’s
wire to connect the amplifier with your passive speakers.
Step 4: Connect the power adapter to BOX X3 and the socket
Turn the Multi-function Knob(Volume Control/Power Switch) clockwise to power on the BOX X3. The input mode indicator light (also the power indicator light) of BOX X3 stays red after power is on.
Note 1: The power adapter does not have a power indicator light, so connecting to the socket means power is on.
Note 2: Before connecting the power supply, please make sure that the BOX X3 is in “OFF” position when connecting to the power adapter. Otherwise there is a “POP” click sound from your speakers.
Note 3: Before connecting the power supply, please turn down the volume control, the bass and treble control to 0 (always to the left) to avoid your hearing from damage.
Step 5: Connect the audio source (MM turntable input, 3.5MM AUX input, Bluetooth input ) to the BOX X3.
(1): MM turntable input: Use RCA Cable to connect your MM turntable to the RCA inputs of BOX X3, then connect the ground wire of your MM turntable to the grounding post of BOX X3.
Note2: MM Turntable Input can only be connected to the turntable, and cannot be used as a normal preamplifier connected to other audio sources, such as mobile phones, MP3, etc.
(2): 3.5mm Input: Use a 3.5mm Audio cable to connect the BOX X3 and your device.
Note: Once 3.5mm AUX plug in ,the MM input will automatically interrupted, so the input mode will turn to 3.5mm AUX input.
(3): Bluetooth Input: Turn on the Bluetooth on your device, then select "BOX X3" for pairing, the input mode indicator light will stays blue after a successful connection.
Note 1: Once Bluetooth is connected, the MM turntable input and 3.5MM AUX input will be interrupted. If you want to use the RCA input again, just disconnect the Bluetooth.
Input priority: Bluetooth Input > 3.5MM AUX input > MM turntable input.
Note 2: Input Indicator Light : After BOX X3 is powered on, the input indicator light on the front panel stays red either 3.5MM AUX input or MM turntable input is successfully connected, and the input indicator light on the front panel of BOX X3 stays blue when Bluetooth input is successfully connected.
Note : Please keep the BOX X3 away from other electric device. The BOX X3 can't use with a radio
simultaneously. When the connection is completed, Please turn on the BOX X3 first, then turn on the amplifier(or powered speakers), at last turn on your turntable or other audio source, then enjoy.
Note: Note: If you turn on the amplifier(or powered speakers) first, then turn on the BOX X3, there is a “POP”click sound from your speakers, it is normal that all the phono preamp have the same issues, please don’t worry about it, the “POP”click sound will not damage your amplifiers or speakers.
