BOX X4
Tube hard to insert (BOX X4)
Kindly refer to the tutorial video by clicking on the provided link. https://youtu.be/hO_fEtDjjjo. 0:12 Make sure the tube pins are properly lined up with the tube socket. 0:34 NOTE 1: Please manually straighten the pins if the pin is deformed.
Input priority (BOX X4)
The 3.5mm input has priority over the MM RCA input. When you plug in the 3.5mm connector, the RCA input will be cut off, but there's no need to unplug the RCA input cable.
Can headphone and RCA outputs be used simultaneously on BOX X4?
Yes, when connected to both the 3.5mm headphone output and RCA output, both headphone and RCA can output.
Difference between BOX X3 and BOX X4
They share the same circuit, with the BOX X3 adding Bluetooth functionality. The parameters for both products are quite similar. The BOX X4 has a headphone output.
How to connect Audio-Technica AT LP60XBT turntable (BOX X4)
Yes, it can function as a phono preamp if the switch of turntable is set to PHONO mode.
Setup: Audio-Technica AT LP60XBT turntable (PHONO Out) → (MM Input) BOX X4 (RCA Out) → (RCA Input) amplifier (Speaker Out) → Passive Speaker.
It can also work as a normal preamp if the switch of turntable is set to "LINE" mode.
Setup: Audio-Technica AT LP60XBT turntable (LINE Out) → (AUX Input) BOX X4 (RCA Out) → (RCA Input) amplifier (Speaker Out) → Passive Speaker.
Kindly refer to the similar tutorial video by clicking on the provided link. Connecting Turntable and Amp to BOX X3 (MM INPUT) https://youtu.be/R1olOekOSfo Connecting Turntable and Amp to BOX X3 (AUX INPUT) https://youtu.be/EfuC1poBsk8
Can't screw in fork Y grounding clip (BOX X4)
There is a hole and an up-and-down function to cover that hole. Depress the lower spring of the grounding post. Insert one end of the forked ground wire into the hole on the grounding post. Release the spring, ensuring that it securely grips the forked end of the ground wire.
How-to Video
How to Connect a Turntable to An Amplifier and A phono preamp
What to Do If Your Preamp Won't Turn On
What to do if pre amp not working
Quick Set:
Step 1: Install the 5654W vacuum tubes to the BOX X4.
Step 2 (OUTPUT) : Connect speakers or headphone (RCA output, 3.5mm headphone output) to the
BOX X4.
• RCA Output : Use RCA cable to connect the RCA line output of BOX X4 to your active (powered)
speakers. Or use RCA cable to connect the RCA line output of BOX X4 to your amplifier, then use speaker’s wire to connect the amplifier with your passive speakers.
• 3.5mm Headphone Output : Use 3.5mm headphone line to connect the 3.5mm headphone output of BOX X4 to your headphone.
Step 3 (INPUT) : Connect the audio source (MM turntable input, 3.5MM AUX input) to the BOX X4.
• MM Turntable Input : Use RCA Cable to connect your MM turntable to the RCA inputs of
BOX X4, then connect the ground wire of your MM turntable to the grounding post of BOX X4.
Note 1: If your MM turntable is no need to connect a ground wire, the ground wire can be omitted.
Note 2: MM Turntable Input can only be connected to the turntable, and cannot be used as a normal preamplifier connected to other audio sources, such as mobile phones, MP3, etc.
• 3.5mm AUX Input : Use a 3.5mm Audio cable to connect the BOX X4 and your device.
Note: Once 3.5mm AUX plug in, the MM input will automatically interrupted, so the input mode
will turn to 3.5mm AUX input. Input priority: 3.5MM AUX input > MM turntable input.
Step 4 : Connect the power adapter to BOX X4 and the socket. Turn the Multi-function Knob (Volume Control/Power Switch) clockwise to power on the BOX X4.
Note 1: The power adapter does not have a power indicator light, so connecting to the socket means power is on.
Note 2: Before connecting the power supply, please make sure that the BOX X4 is in “OFF” position when connecting to the power adapter. Otherwise there is a “POP” click sound from your speakers.
Note 3: Before connecting the power supply, please turn down the volume control, the bass and treble control to 0 (always to the left) to avoid your hearing from damage.
When the connection is completed, please turn on the BOX X4 first, then turn on the amplifier (or powered speakers), at last turn on your turntable or other audio source, then enjoy.
Note: If you turn on the amplifier (or powered speakers) first, then turn on the BOX X4, there
is a “POP” click sound from your speakers, it is normal that all the phono preamp have the
same issues, please don’t worry about it, the “POP” click sound will not damage your amplifiers or speakers.
