The differences in terms of BT30D and BT30D PRO’s Sub out and Pre out functionality.
BT30D: The Sub out is limited to transmitting bass frequencies only. The sub frequency and volume controls apply to both passive and active subwoofers. BT30D PRO: Instead of a dedicated Sub out, the BT30D PRO features a full-range signal port called 'Pre out', which can be connected to either active speakers or subwoofers. When connected to a subwoofer, it delivers low-frequency signals when you set the crossover control on your subwoofer. However, the sub frequency and volume controls only apply to passive subwoofers and do not control the bass frequency or volume of active subwoofers through the Pre out.
Power Output with Various PSUs (Refer to the image below)
I have an active subwoofer connected through the 3.5 mm pre out. Do the sub freq and sub vol knobs only work with a passive subwoofer connected via the passive subwoofer output on the back?
Yes, the 'PRO' Model cannot control the bass frequency or volume of active subwoofer through the preout, the sub freq and sub vol knobs only work with a passive subwoofer.
Can I use Technics turntable with Fosi Audio BT30D Pro?
If your turntable has a built-in preamp, you can connect it directly to the BT30D PRO. If your turntable does not have a built-in preamp, you need to add an external phono preamp to the setup (such as our BOX series). Please refer to the tutorial video through link https://youtu.be/MeFYDHaMsg0
Can the BT30D PRO pre-out also control the frequency and volume of an active subwoofer?
No, the BT30D PRO cannot control the active subwoofer's frequency and volume through the pre-out. The total volume control on the BT30D PRO affects both the active and passive subwoofer volumes. The subwoofer volume is controlled by the subwoofer’s own volume knob.
How do I connect the pre-out to the subwoofer on the BT30D PRO?
Yes, connect the pre-out to the left and right line-in of your subwoofer. The pre-out is a stereo 3.5mm mini plug, so please use a stereo 3.5mm to RCA cable to connect the pre-amp to the subwoofer.
What type of DC-plug I need to buy for power supply?
DC plug is 5.5*2.5mm and has a center-positive connector.
Why are there three speaker outs? The subwoofer out is the 3.5mm pre out?
The third speaker output is dedicated to passive subwoofers. A 3.5mm pre-out allows you to connect with a powered speaker/subwoofer or an external power amplifier with a passive speaker. Kindly refer to the tutorial video by clicking on the provided link. https://youtu.be/WhYpHkovCWs (2:44 PRE OUT)
Can it be connected to active and passive speakers at the same time?
Yes.
Banana plug diameter for loudspeaker output
All Fosi amplifiers use standard-sized speaker terminals, they are standard 4mm pins. Easy to wire up and solidly connect to amplifier and passive speaker. If they do not fit, use a little force to tighten the plugs. Kindly refer to the tutorial video by clicking on the provided link. https://youtu.be/6pYhoqDlvNw
