The dimensions are 28 × 22.5 × 18 cm, which is approximately 11.02 × 8.86 × 7.09 inches.
Component Rack
Amp Rack Mandatory Steps:
1. Remove the protective films from both sides of the acrylic panels (recommend performing this in a well-lit environment to ensure complete removal);
2. If there's a need to install a cooling fan, proceed to the Optional Steps, otherwise, proceed to Step 3;
3. Remove the top screw caps from the four connecting rods, then insert each rod into the holes at the corners of the lower acrylic panel. Align with the screw holes in the conical foot pads and hand-tighten to ensure a secure connection;
4. Place the middle acrylic panel on top of the installed support rods, aligning the holes at the corners. Use the middle rods to secure the acrylic panel to the remaining rods, tightening by hand;
5. Position the top acrylic panel over the upper ends of the support rods, aligning the holes at the corners. Secure the shelf in place using the top cap nuts and tighten them by hand;
6. Place the rack on a flat surface and push-pull it to check for stability, tighten any loose connections as necessary.
If you choose the Amp Rack & Fan Combo, please follow these optional steps to install the cooling fan (using the lower acrylic shelf as an example):
1. Provide your own 12025 specification cooling fan and corresponding screws;
2. Confirm the direction of airflow on the fan, typically indicated by an arrow, ensuring it faces upward (toward the bottom of the device) to effectively cool the equipment;
3. Use a screwdriver and screws to mount the fan to the designated mounting holes on the acrylic panel;
4. Check the stability of the connection and connect the fan to power to test if it operates correctly and the airflow direction is appropriate;
5. Return to step 3 of the Mandatory Steps.
