Can the K5 PRO be connected to external speakers when used with a PS5?
Yes, the K5 PRO can be connected to external powered speakers while using it with a PS5.
What is the power output of the K5 PRO?
1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω.
Can the K5 PRO output to both headphones and RCA simultaneously?
Yes, but you need to disconnect the speakers to use headphones only.
Does it support sidetone?
Yes, it supports sidetone, and you can adjust it in settings. To set up, select "Fosi Audio K5 PRO" as the input in sound settings. In microphone properties, enable "Listen to this device" for the "Fosi Audio K5 PRO" output, and click "Apply." This allows you to control the amount of microphone input routed back to your headphones, letting you hear how much of your own voice you want to monitor.
Is the K5 Pro driverless on Windows 7?
Yes, it is driverless.
Does it support "enhancements"?
Yes, it supports Windows Loudness Equalization enhancements.
What’s the sample rate of USB/Optical/Coaxial?
USB outputs up to 24-Bit 96 KHz, while Optical and Coaxial support up to 24-Bit 192 KHz.
Unable to Power On
Make sure to power on the device correctly by pressing and holding the volume button for a longer time to turn it on. Please refer to the tutorial video for more information: Watch here https://youtu.be/9bObE2Z24Eg (2:37 DAC).
How to use K5 PRO with PS5?
Plug your headset into the K5 PRO via the 3.5mm splitter. For detailed instructions, check the tutorial video at this link: Tutorial Video. https://youtu.be/1eLN2fwpVb4 🎮 Go to Settings > Sound > Audio Output, select Output Device, and choose "Fosi Audio K5PRO." Adjust the microphone level until it's in the optimal range. Ensure both output and input settings on your PS5 are set to "Fosi Audio K5PRO."
K5 PRO works with PC but not with Android phone.
First, check if USB debugging is enabled in your Android phone settings (locate the developer options) and also ensure the OTG function is enabled (found in more settings). Ensuring the 2-in-1 USB Type-C connector is connected to the audio source. Try replacing the USB OTG cable. If the issue persists, your phone may not provide enough power, consider using an additional USB cable for power. If K5 PRO still doesn't power on, consider using an additional adapter for extra power. Please refer to the tutorial video here: Tutorial Video https://youtu.be/9bObE2Z24Eg (📌 3:40 for details on using an additional USB cable for power supply).
