Power supply
How can I ensure that I will receive the correct specifications for a power supply?
The power supply is compatible with AC 110V-240V. We will provide a suitable power plug based on your delivery address. If you require a power supply with a different specification, please make sure to inform us so that we can provide you with the appropriate one.
The BOX X5 specifically comes in two regional versions: 120V (U.S.) and 230V (EU).
What are the dimensions of the DC power barrel connector?
It is a 5.5mm x 2.5mm pin barrel connector, except for a few that are 2.1mm.
Where can I get a new YU190474 19V 4.74A power adapter?
You can find it at the following product link:
