The three op-amps in the V3 Mono serve distinct functions, and it's recommended to start with the one in position 2. However, replacing both op-amps in positions 2 and 3 will result in a more noticeable improvement.
When powering a V3 Mono device, would using a 48V/10A power supply provide a higher power output than a 48V/5A power supply?
Based on our measurements, when powered by a 48V/10A power supply, there is no significant increase in power compared to using a 48V/5A power supply. This is because the power has essentially reached the maximum supported by the TI TPA3255 amplifier chip with a 48V voltage input. Increasing the current further does not directly enhance the power output. However, using a 48V/10A power supply compared to a 48V/5A power supply can provide a higher current capacity and greater safety margin for the amplifier. This increased current capacity effectively reduces voltage drops in power lines and internal circuits under high loads, improving the response of the amplifier when handling dynamically complex audio signals. Moreover, the higher current output means that the system is less likely to overheat or shut down due to current overload when facing peak loads, thereby enhancing the overall reliability and stability of the system. Additionally, opting for a more robust power supply can alleviate the operational stress on various components of the amplifier, prolong the lifespan of the equipment, and offer more flexibility for potential system upgrades in the future.
If you use a single 48V/10A power supply to power two V3 Mono devices simultaneously, compared to using two separate 48V/5A power supplies for each V3 Mono, will the output power be the same? Will there be any changes in other parameters?
Based on our measurement, using a 48V/10A power supply does not significantly increase power output compared to a 48V/5A power supply. Other parameters, such as signal-to-noise ratio, THD, and frequency response, are also virtually identical. Therefore, there is no noticeable difference between the two options in terms of your user experience. We are offering this one-to-two power configuration option for more flexible system building. Of course, by using one less power supply unit, you can save space and achieve a neater system setup.
A KOL pointed out that the V3 Mono runs really hot to the touch. ls that a safety concern?
V3 Mono employs a unique cooling design. We closely integrate the amplifier chip's heatsink with the chassis, effectively turning the entire chassis into a radiator. Additionally, we have included vent holes on the sides of the chassis to enhance air circulation. Since the chassis serves as a radiator, its surface temperature may seem a bit high. However, this indicates that the heat from the amplifier chip is being effectively transferred to the chassis, allowing the V3 Mono to stably maintain high power output continuously. We have also conducted extensive safety testing on the V3 Mono to ensure it poses no safety risk, so please rest assured.
What is the input voltage of the included power supply, and can it be used in my country?
Both the 48V/5A and 48V/10A power supplies support a wide voltage input of 100-240V.
I want to know if I can integrate a BT20a Pro with two V3 MONO in mono into a LC30 switch.
Yes, that works.
I purchased 2 V3 MONO and 2 48V/10A bricks. How will the V3 MONO run with one brick each?
You can safely run each V3 MONO with its own 48V/10A power supply. A single PSU can also power two amps using a splitter.
I have a DAC/preamp with TRS balanced output. How do I connect it to the V3 MONO?
Use a TRS cable to connect the balanced TRS output to the 6.35mm balanced (TRS) input on the V3 MONO.
Does the XLR input accept standard XLR balanced audio cables?
Yes, the balanced input accepts both standard XLR and 6.35mm TRS cables.
Many users believe 48V/10A and 48V/5A PSU feel the same. What’s the difference?
While the output power is similar, using a 48V/10A power supply provides better current delivery, resulting in improved headroom and overall stability.
I want to use two V3 MONOs but prefer not to share a PSU. Is that okay?
Yes, using a dedicated PSU for each V3 MONO is fully supported.
Is a filter needed when using two separate power supplies?
No filter is required when using separate PSUs.
The V3 MONO’s LED doesn’t light up, but there’s sound. What should I do?
Check if the LED got misaligned when swapping op-amps. Open the unit and realign it. Video: LED Fix Tutorial
V3 MONO's Power Output with Various PSUs
(Refer to the image below)
How to connect XLR on V3MONO?
Use an XLR cable to connect the XLR output of your source device to the XLR input of the V3 MONO.
Can I use the V3 MONO with active speakers?
No. The V3 MONO is designed only for passive speakers.
Is the V3 MONO a true XLR-balanced amplifier?
Yes, it is.
If I replace the op-amp in the V3 MONO with the Sparkos SS3602, do I need to change the DIP socket?
The Sparkos SS3602 op-amp is compatible, and you do not need to change the DIP socket.
V3MONO pin standard
American Standard. It is a US XLR signal. Pin 2 = HOT, Pin 3 = COLD
Can one PSU power two V3 Mono amps using a splitter?
You can use a filter and splitter cable to power both amplifiers. Please check the product link for the Power Filter below: https://fosiaudio.com/products/hex-driver-wrench-4-piece-set?_pos=1&_sid=b6a637ae1&_ss=r
What is the correct direction for connecting the filter to the V3 MONO?
Refer to video: https://youtu.be/i9z26-YqiFo. Connect PSU to "DC In", then use splitter to connect to amps.
What are the fosi v3 mono block dimensions?
142*105*35㎜
